intake sensor?
Old Dec 24, 2003 | 07:21 PM
jlsmi2's Avatar
Default intake sensor?
I have a 92 cx with a 94 b18c1 swap and I noticed that there is a plug (seems like it'd be a sensor) that I believe would have plugged into the factory airbox in the general area of the air intake under the hood. I purchased a cheapo "ractive" intake and am wondering if there is a way to use hook the sensor up. I assume that it reads the air temp or something for the o2 mix. What do I do with this sensor, can I hook it up using the ractive intake (no opening for the sensor), if I can't use it should I invest in a different air intake/filter system that I can plug the sensor into, or is it fine to by pass this?
Thanks for any info.
Old Dec 24, 2003 | 08:41 PM
1 point 6's Avatar
Down Since Day 1
Community Builder
Community Influencer
Default Re: intake sensor? (jlsmi2)
Sure its not the breather hole?
Old Dec 24, 2003 | 09:54 PM
thad
Guest
Posts: n/a
Default Re: intake sensor? (1 point 6)
what does it look like? do you have a pic? not very much info to go on.
the intake air temp sensor is ontop of the intake manifold on GSRs and the MAP should be on the throtle body.
Old Dec 25, 2003 | 08:26 AM
jlsmi2's Avatar
Sorry for being vague I'm not sure what it is. Someone suggested that it might have clipped into the air box. And, no its not the breather hole; what i'm talking about is a plug... I'll take pic when i get a chance. The plug is located near where the airbox would be on a 92cx. Its right around the hole that many people drop the cold air intake's into...
Hope this helps..if not i'll post a pic soon..
Thanks
Old Dec 25, 2003 | 02:01 PM
VTECVillain's Avatar
There is no sensor plug in the airbox for any 92-95 Civic. I can't think of any plug in that area unless it would be for the cooling fan, possibly A/C or something. If you can get a pic up then it will help us help you.
Old Dec 25, 2003 | 02:58 PM
Turbogixxer's Avatar
Default Re: intake sensor? (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">There is no sensor plug in the airbox for any 92-95 Civic. I can't think of any plug in that area unless it would be for the cooling fan, possibly A/C or something. If you can get a pic up then it will help us help you. </TD></TR></TABLE>
I am thinking of the plug for the sub-harness for the a/c. does the car have a/c? how many wires is it?
Old Dec 25, 2003 | 06:18 PM
jlsmi2's Avatar
Default Re: intake sensor? (turbogixxer)
its a cx model and does not have an ac...i'll take another look at it, see how many wires and take a shot so maybe we can figure this out..
thanks again.
Old Dec 26, 2003 | 07:47 PM
thad
Guest
Posts: n/a
my Ex has quite a few plugs in the area , ie. horn, radiator fan headlight and several i'm not sure about, there is also a bunch of wires that go into a small box and are grounded on the body by a 10mm bolt.
hope this helps a little
Old Jan 7, 2004 | 05:30 PM
jlsmi2's Avatar
i found out what it was...it was the IABs... one pink, one black/yel coming from under the manifold... thanks for the input
stefo
Honda Civic (2001 - 2005)
Sep 8, 2009 08:56 PM
creepy116
Dec 19, 2007 10:33 PM
ewn1603
Sep 21, 2004 05:53 PM
supernova
Dec 3, 2001 06:49 AM
