injector resistor box ???
Old Feb 13, 2005 | 03:58 PM
turbox's Avatar
Default injector resistor box ???
im putting a 95 gsr motor in a 90 crx si i have been working on the engine harness for like half the day now swapping obd-0 connectors to obd-1 now im at the injector resistor box i have the 8 wire cap off off of the obd-1 harness
my ? does the red/black wire connect to all the yellow and black wires?
planning on soldering on the 8 wire cap someone said just solder them all together"??ive almost got this thing ready to go this is holding me up
thanks chris
Old Feb 13, 2005 | 10:22 PM
eda6's Avatar
Default Re: injector resistor box ??? (turbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbox &raquo;</TD></TR><TR><TD CLASS="quote">planning on soldering on the 8 wire cap someone said just solder them all together"??</TD></TR></TABLE>
No soldering is needed since you have that obd1 plug.
Depin the harness side of the plug that goes to the resistor box. Next depin the 8 wire obd 1 plug. Repin the 5 wires into the obd1 plug and put the cap back in. Now each injector will get 12V. You're done. Find some blanks to fill in the unused holes on your obd1 plug. You'll need 6.
88todab16crx
Oct 5, 2008 05:22 PM
boostng r
Jan 22, 2005 03:22 PM
fffrog
Feb 3, 2004 04:10 PM
jdmcivicferio
May 6, 2003 10:53 PM
bruthaboost
Dec 17, 2001 09:08 PM
