injector problem h22 ek
Old 02-13-2005, 03:53 PM
soquickls's Avatar
Default injector problem h22 ek
we just put a h22 in ek now there is a problem i believe its the no2 cylinder middle to the right side of motor..when starting the car it throws a massive amount of gas...this is what i thought of fist thought maybe the injector was bad so bought a new one same thing happened all the gas flowed out...then thought maybe the spark plug went out so replaced it...now it catches on fire and gas still burst out...then i tried using a different plug wire...samething....i am stumped i double checked to make sure that the wire was on the right injector...and it was...can anyone help me please!!!
p.s its weird cause in the h22 harness it looked like it was saturated injectors cause the yellow wires were plugged up...but the injectors use the obd0 type plugs...and the guy told me that the h22 was a 97 if that helps thanks
ram0869
06-12-2008 08:30 PM
mikegeezy
03-19-2006 10:14 PM
Jago
09-03-2004 09:36 PM
96hatch22
08-18-2003 11:56 PM
Quick Reply: injector problem h22 ek
