im tryin to bar my usdm gsr swap in California
#29
Re: im tryin to bar my usdm gsr swap in California
^ yes. Usually it means you spent a month or so getting your engine temporarily in inspection order just to appease the state then you tear it all off when you're done
#30
just gotta bar your car or have a car that comes with a stock b-series motor and your good no worries. i have a b-series in my ek and i dont get hassled or pulled over
#31
oh yeah and JC i heard you were able to bar it finish up this thread and tell everyone what happened when you went and what city ref you went to.
im going to try to bar my car soon.
#32
#33
^ that would be the best bet for now. KEEP IN MIND that you still need to pass emissions every once and again, so when you build, if it takes a little more money to keep things as close to legal as possible then do it...save parts you may need later down the road...I won't claim to know everything I live in FL so I've never had to go through it but I hear about the mess from my friends in cali allll the time.
#34
CA is the best and f*ck the rest
#36
I had 2.5inch piping and he never even mentioned it when I went for my inspection.. Just make it as stock as you possibly can.. No hanging wires, no aftermarket mods(even if theyre carb legal).. Youll be fine if everything is legit and you pass emissions.. You also need paper work on your motor to prove its legit!
#37
damn i forgot to close this thread , but im going to give you as much info as i can , this is how i passed BAR:
complete sctock B16a2 , original cams , header , harness ( no conv), Em1 charcol canister, pretty much just a stock motor . According to the referee most of the mistakes or the reason why they FAIL some people is usually for the wiring , for example cutting wires or using stock cx, dx wires they notice that. I had my ps plug hanging and he saw that but he knew what the wire was for so not really much of a deal. on the piping 2 1/4 was fine with catalytic of a Si, must be running both o2 sensors , on the o2 make sure you use the Si one for some reason my 02 sensor from the stock motor went bad after 3 days of the swap , i got two off 95ProjectEJ1 and that was fixed (thnks J ). on the exhaust i went with a Gsr axle back NOTE: don't take an aftermarket one since they smog the car there and if the exhaust is too loud they will make you come back !!! guy before me failed because of the exhaust , stock ECU and if you're running vtec make sure to run the wire to cabin as legit as possible, since he said "if we see a mickey mouse on the wiring, that tells us there's some more on the swap and we tell them to come back" . BTW no carb legal parts even tho they are carb legal , you must take the OEM parts. The good thing about getting it BAR'D is not to worry on getting your hood popped and $8.00 smog check. They smog your car and you just pay for the BAR sticker $ 8.00 and smog is good for 90 days. For the BAR i went to LATTC.. here's some pics
#38
1 Post
i got my gsr bard in my ek in 2009. they dont do smog at the bar staions anymore. all they do there is inspect your car for the proper emissions equipment. pretty much just visual. so just make sure you have all the right stuff for your motor, also smog and street legal. make sure your not throwing check engine codes. they give you a sticker afterwards. you dont have to smog right away. you can wait till its time to go, youll be using that sticker for smog from there on.
#41
good info...
but there's still one more question...
Can you use a jumper harness? Like Rywire for instance..it's all plug and play of the finest quality.
#42
The Grumpiest
Did jumper harnesses come standard from Honda? Then I would say no, you can't use one and go get the correct ECU for your engine.
#43
Normally I say thanks good info....lol..but in this case.
Rywire not of the highest quality? Do you make better stuff? lol.....
..and what experience do you have with getting your car Bar'd in Tennessee?
Oh, I mean Cali?
Oh, I mean Cali?
#44
The Grumpiest
I have read this thread and others and what people FROM California are saying so it it pretty evident to me that your car and it's jumper harness more than likely will not pass a visual inspection. Other threads have also stated the exact same thing. So even though I don't live in Cali, I have read these threads and learned that if I were to say, move there, what I would have to do to make sure my car was able to pass insepction.
But you know. What I don't understand is why don't you get it straight from the horses mouth instead of posting up here? From what I also understand Cali's BAR standards seem to change like the wind and even from station to station and even the individual who actually inspects your car..
And I have no doubt Rywire is of the "highest quality" but what does that have to do with anything? As if a lesser quality harness, whatever you may deem that to be, will fail and the Rywire one will not? Quality of the harness has no bearing.
#45
#47
Sure..I will def..let you know, like I said I'm human. It's my first time trying BARD.
The REF told me out of the hundred's of cars he's done, only 3 cars
made it through the first time anyhow, so I'm up for the challenge.
#48
What the hell is the point in the state doing all of this? Why do they find stuff to purposly fail you on? Do they get paid on how many cars they fail?
#49
#50
Yeah,I wanna swap but all I hear are horror stories.I moved here last year from the north east and they dont care what you run under the hood out there. I never ran a single cam so long before and its driving me nuts!
