Ignition timing adjusting connector?
Old Jun 18, 2003 | 01:18 PM
BIG RICH's Avatar
Default Ignition timing adjusting connector?
OK, while I was doing the wiring changes at the ECU for a DX-ZC swap. this wire got pulled out of it's pin. It's in spot B20. I couldn't get the pin out. Does anybody know what this controls?
Old Jun 19, 2003 | 12:58 PM
BIG RICH's Avatar
Default Re: Ignition timing adjusting connector? (BIG RICH)
OK, so there is a conector you have to jump when checking your timing. could this be it?
Old Jun 20, 2003 | 07:22 AM
jlicrx's Avatar
yes, B20 is the ignition timing jumper connector
Old Jun 20, 2003 | 11:05 AM
BIG RICH's Avatar
Default Re: Ignition timing adjusting connector? (jlicrx)
thank you. Also, what is the easiest way to remove the pins from the connectors? I had a hard time and couldn't get it out.
Old Jun 22, 2003 | 05:03 PM
lcaruca97's Avatar
use a paper clip to get them out. Shove it in on top of the wire and then once its in, pull the wire out. If the wire doesn't come right out, you need to put the paper clip in further.
Donkey85
13
Aug 3, 2011 12:08 PM
blazzer
Apr 14, 2010 10:48 AM
Dunc
Dec 8, 2006 06:34 PM
thatbluecrx
Feb 27, 2005 10:15 AM
