V-tec only works in first and second
Old 01-16-2009, 11:58 PM
93eghb's Avatar
Default V-tec only works in first and second
I have a 0bd1 b18c in an eg with a chipped po6. car sat for a month in the shop because I snapped an axle. When I got the car back v-tec doesnt have the same power in first and second and doesn't even crack in 3rd-5th.
93eghb is offline
Old 01-17-2009, 12:03 AM
halocore's Avatar
Default Re: V-tec only works in first and second
try a different ecu to see if it works,
halocore is offline
Old 01-17-2009, 12:20 AM
How are you sure VTEC is engaging or not?
trustdestruction is offline
Old 01-17-2009, 09:49 PM
93eghb's Avatar
big loss of power and I can't hear it at all. The eletrical part of v-tec is working we already figured out but The oil pressure side of it or ecu is all i can think of.
93eghb is offline
Old 01-17-2009, 09:55 PM
SiYouLater's Avatar
Dumb question, but did you check your oil?
SiYouLater is offline
Old 01-19-2009, 11:53 PM
93eghb's Avatar
oils fine.
93eghb is offline
Old 01-20-2009, 12:07 AM
teamworxek9's Avatar
Vtec wont work without the vtec oil pressure switch to activate it, so how did you figure the vtec selinoid is working? Switch out your ecu. Id hard wired a led from the engine bay to the cabin to make sure the vtec is working. Try doing the same for both parts of the system.
teamworxek9 is offline
got_no_sol
04-11-2008 08:51 PM
boosted k20
07-21-2005 07:15 PM
red-eg6
07-13-2005 11:25 PM
b19coupe
09-03-2003 07:02 PM
vspec12
11-05-2001 05:25 AM
Quick Reply: V-tec only works in first and second
  • Ask a Question
Question Title:
Description:
