how do i adjust traction bars?
Old Sep 18, 2003 | 09:10 AM
hondaeg5's Avatar
Default how do i adjust traction bars?
just as the topic states. thanks
Modified by hondaeg5 at 12:01 AM 9/19/2003
Old Sep 18, 2003 | 08:03 PM
hondaeg5's Avatar
Default Re: how do i adjust traction bars? (hondaeg5)
Old Sep 19, 2003 | 12:18 PM
92b16vx's Avatar
You need to get it aligned once it is done, and when it is aligned, tighten everything in place with some locktite on the threads so they don't back off.
Old Sep 19, 2003 | 04:40 PM
_BEN_'s Avatar
Default Re: (92b16vx)
Im kinda interested too. What about preload so there is a little tension pulling or pushing? Or do you just line up the holes and its set?
Old Sep 19, 2003 | 04:50 PM
95hbMatt's Avatar
Default Re: (nosepkr)
wants to know too!!
I just put on my jimfab bar and have no idea on how to adjust it...
Old Sep 19, 2003 | 04:51 PM
sackdz's Avatar
At least on the DC2 chassis, the aligment won't change a whole lot, but you want to preload the bars in tension, meaning pull the suspension toward the front of the car. Not a whole lot, maybe 2 or 3 turns from neutral.
Old Sep 20, 2003 | 06:25 PM
hondaeg5's Avatar
Default Re: (sackdz)
the directions state:
1. with the wheels pointing straight ahead,roll the vehicle back and fourth for about 5 feet in either direction. this will settle the suspension and make for accurate adjustment.
2. with the strut rod jam nuts loosened,adjust the strut rod length by turning until the front bolt slides back and fourth freely. tighten the jam nuts.
3. repeat procedure for both sides.
4. depending on height of the vehicle,different angles of the strut rod may produce better performance.
now i have no idea what they mean.(lol) i mean it sound pretty straight forward but i still have some wheel hopp after installing these. my car is slammed though so im wondering if i should be adjusting them another way.
kalbs
Suspension & Brakes
12
Aug 15, 2007 06:33 PM
92hatchattack
Suspension & Brakes
Jun 17, 2006 08:44 AM
Draco
51
Jan 16, 2006 12:07 PM
bravoecho11
Dec 22, 2004 12:54 PM
KStuned
Sep 30, 2003 10:58 PM
