HELP:removing obd1 harness for obd2
Old Aug 9, 2003 | 12:11 AM
civicsirplus's Avatar
Default HELP:removing obd1 harness for obd2
I want to remove the obd1 harness in my EG and replace with an obd2 harness for my JDM ITR motor. How hard is it to replace a wiring harness? any instructions?
OR is there any easier way to make the JDM ITR engine work with the already install OBD1 harness? I figure that cos the distributor/etc is different it is better to change the whole harness or can i cut 'n splice?
Old Aug 9, 2003 | 11:45 AM
c'mon i know some of you have done this before!!!
Old Aug 9, 2003 | 11:38 PM
salbaje's Avatar
Default Re: HELP:removing obd1 harness for obd2 (civicsirplus)
make an obd1 to obd2 ecu harness
Old Aug 10, 2003 | 05:04 AM
b19coupe's Avatar
Stick with OBD1, you have more fuel management options and less headaches. Some guys like to cut and splice the distributor wiring, I prefer swapping distributor guts (cleaner) . Another benefit of OBD1 wiring is that RC injectors plug right in-no clips required
TravisBiggie
May 24, 2012 07:13 AM
Prudz_lude
Dec 3, 2008 06:41 PM
Cractos
Jul 26, 2005 10:47 PM
danxdan
Jul 13, 2005 03:37 PM
253EK
May 20, 2004 10:52 PM
