Can I rewire obd1 distributor to work with an OBD2 harness?
For example... can I cut the *2* OBD1 Distributor plugs off and use the *1* obd2 Distributor plug from the obd2 distributor. It has the same amount of total wires. But I dont have the helms manual telling me which wire is which. And some of the wires are different colors....
So any help here guys-
Re: Can I rewire obd1 distributor to work with an OBD2 harness? (TurbLu)
Sorry the reason behind all of this is I am replacing my blown b18c (obd2) with a JDM b16a (SIR2)(obd1). And on my harness I have a large 10 plug Distributor plug vs. the 2 part distributor plug on the b16a. So can I use the plug from the gsr dizzy on the b16a dizzy?
bump help please...this is the last thing before I can drop this engine in.
when i was gonna drop my obd1 b16a in my obd2 civic..my friend just changed the casing for the dizzy...worked like a charm... instead of rewiring all that ****.. took all obd1 junk and threw it inside obd2 casing..
Re: Can I rewire obd1 distributor to work with an OBD2 harness? (b16delteg)
Re: Can I rewire obd1 distributor to work with an OBD2 harness? (Marauder)
so that Rywire distributor harness is for puting an obd-1 distributor on a obd-0 engine, like a 1st gen b16?
But what about if i wanted to put on a obd-1 distro on a obd-0 engine to swap in a obd-2 car? Will that harness work or will i have to completely rewire the distro wiring?
Mr. Badwrench
http://www.lowcashracing.com has dizzy adapter harnesses now for like 25 bucks.
Re: Can I rewire obd1 distributor to work with an OBD2 harness? (boostedcivicsir)
There is no need to get any adapter harness. De pin it and repin it to an OBD-2 plug. Its as simple as that.
efdrifter
11-08-2007 09:14 AM
DIYMIKE
02-23-2007 09:06 PM
Blown90hatcH
02-11-2003 01:26 PM
