help tranny swap
i have a 98 civic ex...i'm trying to do a auto to 5 speed conversion....does anyone kno exactly what parts i will need? thanks so much
Ben |
Re: help tranny swap (PolosportZ81)
what's up, ok, you'll need shift limkage, man. trans., clutch m/c, clutch hard lines, clutch pedal set(clutch and brake are one unit), manual ECU, manual motor mouonts, clutch slave cylinder, short throw, manual console, Si gaugecluster, manual throttlecable, 3 quarts honda manual tranny fluid, manual flywheel, clutch set(of your choice) and pilot bearing. that should be all you need todo the swap into your '98 Civic EX and shift away. . . . .
Re: help tranny swap (WykidEG6)
ok
I have no intention of trash talking, but you migh consider another option.Just keep saving your money and put in a B16, it is cheap, in my opinion easier than swaping the transmission. and the performance gains are far greater than doing a 5speed tranny.
Just a thought Randal |
Re: help tranny swap (PhucNguyen57)
no no i'm thinking of goin turbo after i do the swap instead of gettinga b 18b and doin a swap...thanks for replying tho
Ben |
put in a B16... the performance gains are far greater than doing a 5speed tranny. |
