Stretched head bolts.....
Old May 18, 2003 | 12:00 PM
jdm-spec-eg's Avatar
Default Stretched head bolts.....
Just out of curiousity, what would happen if you installed stock head bolts that were stretched beyond spec?
Old May 18, 2003 | 12:17 PM
fizzbob7's Avatar
Default Re: Stretched head bolts..... (jdm-spec-eg)
more than likely you'd be replacing the head gasket later or even replacing the head if it overheated and warped badly.....why do that....new ones aren't that much
Old May 18, 2003 | 01:49 PM
Default Re: Stretched head bolts..... (fizzbob7)
Would it give you an incorrect torque reading??
I installed a 00 GSR head with 30,xxx kms on it to a rebuilt bottom end. It is now leaking coolant into #1, #3 and #4 cylinders only when the motor gets hot.
The block and head were decked..
Old May 18, 2003 | 02:01 PM
4DeepCivic's Avatar
No, it won't give you false torque reading.
twocross
Feb 23, 2011 03:07 PM
steveharrmr23
Jul 21, 2008 10:28 AM
DaYZeD.1
Mar 28, 2008 09:19 AM
memorybox
Oct 21, 2006 09:02 PM
Soccerking3000
Sep 1, 2004 06:29 PM
