HELP!!! NO VTEC W CORRECT WIRING. B16A1 IN 89 CIV SI - knock sensor values?
Old 06-29-2003, 12:11 PM
Freeltec's Avatar
Default HELP!!! NO VTEC W CORRECT WIRING. B16A1 IN 89 CIV SI - knock sensor values?
I have no vtec
i need the proper ohm resistance reading of:
knock sensor
vtec solonoid
oil pressure switch
so i can test whats screwed. all wiring seems proper. all sensors wired.
Old 06-01-2004, 01:18 PM
cstay's Avatar
Default Re: HELP!!! NO VTEC W CORRECT WIRING. B16A1 IN 89 CIV SI - knock sensor values? (Freeltec)
bump also need
Old 06-01-2004, 05:09 PM
agCrX's Avatar
Default Re: HELP!!! NO VTEC W CORRECT WIRING. B16A1 IN 89 CIV SI - knock sensor values? (cstay)
I was curious about this the other day actually, i have handy here the VTEC Solenoid Resistance...
Should be between the one connector and ground (duh) resistance of 14 to 30 ohms. anything different needs some replacing
And this is according to alldata
B18cHatch06
09-30-2005 11:39 PM
pr3crx
02-05-2004 10:04 AM
yellowmonkeyboy
06-29-2003 02:35 PM
Quick Reply: HELP!!! NO VTEC W CORRECT WIRING. B16A1 IN 89 CIV SI - knock sensor values?
