help on del sol swap?
i am trying to get parts for a del sol swap
i am going to be using a 91 ls motor and i don't know what year ls ecu i can use can i use a 94 ecu?
also can i use the stock sohc injectors on the ls motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KaBooM »</TD></TR><TR><TD CLASS="quote">i am going to be using a 91 ls motor and i don't know what year ls ecu i can use can i use a 94 ecu?</TD></TR></TABLE>
It depends on the year of your Del Sol as to the OBD ECU that will plug into your cabin harness. If you have a 93-95 then the OBD1 LS ECU will work, if you have a 96-97 then you would need an OBD2 to OBD1 ECU adapter harness to use it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">also can i use the stock sohc injectors on the ls motor</TD></TR></TABLE>
Yes they have the same flow rate.
