Help! Code 13, JDM H22A Civic
Old Aug 10, 2004 | 03:56 PM
RotiEatter's Avatar
Ditto
Default Help! Code 13, JDM H22A Civic
I just swapped a JDM H22 into my 92 Civic DX. The first time I started up the car was with the stock P06 ecu and i let it run for a couple minutes, no codes. Later on I started it with the JDM P13, and got a code 21. I reset the ECU and that code was gone. I started the car up again with the P13 and now I have code 13. What could cause this and what are the steps to fix it? Please keep in mind the car has never been driven yet with this motor. Also I triple checked the wiring to the ECU and it is fine. If you need anymore info let me know. Thanks.
Old Aug 10, 2004 | 09:36 PM
v4lu3s's Avatar
RTFM
barometric pressure sensor. to fix it you typically replace the ecu since it is IN the ecu.
Old Aug 10, 2004 | 10:24 PM
RotiEatter's Avatar
Ditto
so I need a new ecu? damn,
Old Aug 11, 2004 | 01:28 AM
Turbogixxer's Avatar
Default Re: (RotiEatter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote">so I need a new ecu? damn, </TD></TR></TABLE>
You sure you checked the wiring right? plug the po6 in and see if you get the same codes (minus vtec, egr, knock)
Old Aug 11, 2004 | 01:29 AM
Ransom's Avatar
ive got a p13 sitting here waiting for a good home...pm me if you want it
Old Aug 11, 2004 | 05:39 AM
v4lu3s's Avatar
RTFM
the barometric pressure sensor is the one that is inside the ecu, its a little black bos looking thing sticking up in one corner if it is a usdm ecu, if it is jdm it is a little card with some stuff on it in the same spot. if that sensor is bad the way to replace it is desolder it, and solder a good one in, however that usually means destroying a second ecu.
least that is what i have always read.
Old Aug 11, 2004 | 01:51 PM
RotiEatter's Avatar
Ditto
Default Re: (v4lu3s)
I plugged up some vacuum lines that were unhooked and the code 13 went away with the stock P06. I am going to try the P13 in a little bit and see what that does.
Old Aug 11, 2004 | 02:54 PM
RotiEatter's Avatar
Ditto
Code did not come up with the P13 either. Now I just need to get rid of this damn code 7
raverx3m
Engine Management and Tuning
Nov 30, 2012 08:49 PM
HOTSHOT-H22A
Apr 21, 2004 09:35 AM
SolidSpruce
Apr 23, 2003 05:33 PM
td04civic
Oct 2, 2002 08:11 PM
ang
Nov 27, 2001 09:38 PM
