H2b problem!!!!
Hey i just ran into a problem and hopefully someone can help!!
i was installing everything on the motor and i noticed that on the h2b flywheel the is no dowels that are there to hold on the pressure plate!!! it is a evo kit by the way!
so i'm thinking that it was just not included cause if i were to put the clutch and pp without the flywheel i don't think it will hold!!
let me know what i can do!!
thanks
thanks
Give EVO a call tomarow or you could just get some dowel pins out of your other flywheel if you have one. Also you could go down to your local machine shop and they should have some there you could buy if you dont have any.
incredteg3
Feb 11, 2005 06:24 PM
Rocks
Jul 28, 2004 12:09 PM
jdmEKhb
15
May 1, 2003 01:39 PM
