h22a question for swap
Old Aug 17, 2004 | 08:19 AM
Subwarrior's Avatar
Default h22a question for swap
I'm almost finished with my 6thgen accord/h22 swap. I need some info on the jdm h22. I converted tranny from auto to 5 speed without a hitch. But I have found 2 hydraulic lines in the back of h22 transmission. I suspect they are tran fluid cooler lines, but on a manual???!!! I know the auto trans have atf cooler lines, but this was a first for me. My resource atlocal honda dealer couldn't find me an answer because it's a japan motor. So, callin out to anyone with an h22a!!!
Old Aug 17, 2004 | 12:21 PM
Adam.'s Avatar
Default Re: h22a question for swap (Subwarrior)
It is for the power steering on the VSS. Loop them.
Edited for a confusing spelling mistake.
Modified by DarkKnight[DMD] at 11:51 AM 8/18/2004
Old Aug 17, 2004 | 02:38 PM
Subwarrior's Avatar
Default Re: h22a question for swap (DarkKnight[DMD])
pwr steering lines on back of tranny? I refuse to say you're wrong because I have no idea. Are we talking about the same lines? Because the steering lines are hooked up...The lines I am referring to are on passenger side, coming from transmission. I repeat, not saying you're wrong, just trying to be sure.
Old Aug 17, 2004 | 05:17 PM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Subwarrior &raquo;</TD></TR><TR><TD CLASS="quote">pwr steering lines on back of tranny? </TD></TR></TABLE>
Believe it.
Old Aug 17, 2004 | 05:50 PM
v4lu3s's Avatar
RTFM
its called speed sensitive power steering.... i know 4th gen accords have it.
Old Aug 18, 2004 | 07:17 AM
Subwarrior's Avatar
Default Re: (v4lu3s)
I'll buy that, it makes good sense. Now do automatic cars have that? I didn't have those lines on stock tranny is why I ask, and I have nothing to run the lines to that I can see. Can you specify what you mean by "loom it"? What would happen if say, I were to plug them? Thanks for the help guys.
Dr.green
Oct 3, 2007 11:36 AM
Mikey361
Feb 9, 2006 09:10 AM
Eggman
Jul 12, 2003 01:20 PM
CvexH22
Mar 11, 2003 12:04 PM
92JDMSiR
Jan 16, 2003 12:40 AM
