H22A HELP MAP SENSOR and vacuum hoses
Ok i got a 92 honda accord i swapped it with a h22a .
I need some help with my vacum lines.
i've found different diagrams but it dont help with what my problem is.
i got everything hooked up besides the most of the vacuum hoses.
im confused if i should use the black box that is located near the firewall and the fuse panel. and also with the map sensor. the h22a has the map on the tb and i have mine on ghthe firewall. where do i hook up the map vacuum hose to?
im a lil confused if some could help me or send me a picture of thier swapped h22 in thier cb7 on the vacuum hoses that would be awesome
Re: H22A HELP MAP SENSOR and vacuum hoses
I'm thinking since you're using h22a ecu you'd have to use h22a map sensor, but you'd get faster replies if you post this in the prelude forum.
