h22a Ek header clearance under the car?
Old 06-10-2003, 09:43 AM
Propulsion's Avatar
Default h22a Ek header clearance under the car?
hey all you h22 civic guys, how's the header clearance under the car? does it hang low? how does it compare to a b18 motor/header? I know I would kill myself if I dented a $1000 header. Only plan to lower the car about 1.5".
Old 06-10-2003, 09:49 AM
junglerunna's Avatar
Default Re: h22a Ek header clearance under the car? (SilverCIVIC96)
My header is pretty low to the ground even with about 1.5 inch drop. I just scraped the headers hard last weekend, and flatten the headers a tad.
Old 06-10-2003, 09:54 AM
Old 06-10-2003, 12:35 PM
H22ek4's Avatar
Default Re: h22a Ek header clearance under the car? (junglerunna02)
my hotshot header is like 2 inches off the ground and my car is not even drop that much, just enough to fill up the gap between the fender and wheel. If you look at it in the front you can see my header hanging.
Old 06-10-2003, 12:47 PM
Default Re: h22a Ek header clearance under the car? (H22ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22ek4 &raquo;</TD></TR><TR><TD CLASS="quote">my hotshot header is like 2 inches off the ground and my car is not even drop that much, just enough to fill up the gap between the fender and wheel. If you look at it in the front you can see my header hanging.</TD></TR></TABLE>
Same here
Old 06-10-2003, 03:16 PM
Jonathan_ED3's Avatar
I haven't banged mine up hardly any yet....I'm on stock 153K shocks and Progress springs with 185-65-14's
Old 06-10-2003, 03:22 PM
poison's Avatar
Default Re: h22a Ek header clearance under the car? (hot_EH)
Mine hangs pretty low. But I haven't had any issues with scraping the oil pan or the header b pipe. I'm also slammed about 2 3/4" to 3" as well.
I guess I just know how to drive around slammed cars lol
Old 06-10-2003, 04:23 PM
Propulsion's Avatar
Default Re: h22a Ek header clearance under the car? (poison)
what kind of header, 4-1 or 4-2-1 are u guys using? Will 4-2-1 alleviate the problem slightly?
Old 06-10-2003, 05:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCIVIC96 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of header, 4-1 or 4-2-1 are u guys using? Will 4-2-1 alleviate the problem slightly?</TD></TR></TABLE>
Mines 4-2-1. You just have to know how to drive a lowered car.
Old 06-10-2003, 05:17 PM
poison's Avatar
I also have the factory 4-2-1 H22 header. I also have an EG so the EK engine bay is slightly taller and wider.
Just like junglerunna said, just have to be paranoid and know how to drive a lowered car, making sure you won't ground it out.
Old 06-11-2003, 06:35 AM
EK22Tim's Avatar
Bingo. Pot hole-ridden roads in upstate NY: 1
Civic H22: 0
I have dented my oil pan AND my downpipe. That was with the skunk2's though. It was slammed then. now i'm riding on Neuspeed sports with AGX's. I like the ride so much better and I don't dent stuff.
Old 06-11-2003, 09:23 AM
Propulsion's Avatar
this is a serious problem then, so I come back to my original question for those of you with the experience: how does the clearance compare between a b18 vs. H22 in a civic?
Old 06-11-2003, 12:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCIVIC96 &raquo;</TD></TR><TR><TD CLASS="quote"> this is a serious problem then, so I come back to my original question for those of you with the experience: how does the clearance compare between a b18 vs. H22 in a civic?</TD></TR></TABLE>
Im pretty sure the header clearance can not be significantly different. Either way driving with caution is a must.
Old 06-11-2003, 12:54 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junglerunna02 &raquo;</TD></TR><TR><TD CLASS="quote">
Im pretty sure the header clearance can not be significantly different. Either way driving with caution is a must.</TD></TR></TABLE>
Especially with a lowered car.
Old 06-13-2003, 04:31 AM
cccya's Avatar
untill i started driving like a lowered car, i scraped my DC sports a couple of times. was lowered, about 2.5-3" no only about 1.75". don't care about it though. DC sports headers imo
da9pwnsu
09-06-2010 09:39 AM
MADBADGER
Honda S2000
01-19-2008 11:02 AM
flatty
26
04-03-2006 03:58 PM
d_mina
05-18-2003 11:42 PM
Quick Reply: h22a Ek header clearance under the car?
