Fan Plug on Harness
Fan Plug on Harness
My car nearly overheated the other day so I popped the hood and found the two wires on the plug were broken. The plug was still attached to the block but the wires had pulled out of the plug. The car is a 94 DX and the motor is a b16. I have and extra harness laying around off a 96+ can I use any of the plugs that look like the one that broke and solder it into my harness? Is this a part I can buy from Honda? I'm running a manual switch to cut the fan on now but it's going to get warm soon and I want this fixed.
Are you talking about the fan switch on the engine or the plug for the fan off the main chassis harness?
Either way, yes, if the plug is the same shape, it should work just fine. There are only so many types of honda plugs. If it's the one on the fan switch, it should be the same as the IACV, vacuum purge, IAT, etc. No worries.
chirp the 1-2
12-12-2007 06:47 AM
blinger
04-25-2007 02:00 PM
