h22 shifter
Old Feb 17, 2005 | 10:46 PM
7926's Avatar
Default eg console with h22
do any of you with h22s in a eg have a problem with the center console? with mine...the shifter is down a lot lower (closer to the rear) so i cant get it into the bottom gears. the way it is right now, i screwed to top 2 screws that holds the cup holder part in place....so when i shift the whole console goes up....not really a big deal but i just wanna noe if any of you has experiance this and what did you do
Modified by 7926 at 8:14 AM 2/18/2005
Old Feb 18, 2005 | 02:09 AM
enigma94's Avatar
Default Re: h22 shifter (7926)
Old Feb 18, 2005 | 02:11 AM
enigma94's Avatar
you have to cut 2 wholes and run it like this.
Old Feb 18, 2005 | 07:11 AM
7926's Avatar
Default Re: h22 shifter (enigma94)
lol im sorry i asked the wrong question....
Old Feb 18, 2005 | 09:34 AM
EKhothatch's Avatar
Cut it so you can mount it under the car. I was thinking about doing that this time since last time just mounted in on top where the old shifter was.
Old Feb 18, 2005 | 04:43 PM
hatch22's Avatar
Default Re: eg console with h22 (7926)
My eg has a hole cut like that, and it works pretty well. Shifter is a little down and to the left, but no shifting problems.
Old Feb 18, 2005 | 05:53 PM
darkdementshun's Avatar
Default Re: eg console with h22 (hatch22)
yeah, just mount the shifter under the car and cut the hole a little bigger. Just work with it and you will figure it out. That car will be fun as heck when you can ****** second really fast
Old Feb 19, 2005 | 08:14 AM
7926's Avatar
Default Re: eg console with h22 (darkdementshun)
so you saying mount if from underneather the car? how would this help? any pictures of it?
Old Feb 19, 2005 | 03:12 PM
AudioFuct's Avatar
if you mount it from underneath you wont have to deal with the shifter bracket at all. It will just be 4 bolts. I mounted mine from on top, and ended up having to shave some of the bracket down in order for the console to fit correctly.
Old Feb 20, 2005 | 01:04 PM
7926's Avatar
Default Re: eg console with h22 (AudioFuct)
ooh i see...thank you
Old Feb 20, 2005 | 06:18 PM
jdmcivicferio's Avatar
I didn't like cutting it like that, the cables bind to easily, I never understand why no one goes right through the firewall like me.... so much easier
Old Feb 21, 2005 | 02:21 AM
AudioFuct's Avatar
Default Re: eg console with h22 (jdmcivicferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">I didn't like cutting it like that, the cables bind to easily, I never understand why no one goes right through the firewall like me.... so much easier</TD></TR></TABLE>
newman did
bourdeau9
Jun 2, 2008 11:16 PM
jdmvtecej2
Apr 10, 2008 09:29 AM
NICEHATCH
Feb 6, 2005 05:11 AM
GOLDBERG
May 23, 2003 06:53 AM
