h22 in ek (shifter?)
Old Feb 17, 2003 | 08:44 PM
Kermit EK's Avatar
Default h22 in ek (shifter?)
anyone no where to get pics or instructions on the shifter and cable install into a 96 up civic? Also wiring and ecu info would be great! Thanks!
Old Feb 17, 2003 | 10:56 PM
H22EK's Avatar
Default Re: h22 in ek (Kermit EK)
the shifter is simple take out all you center console **** and go straight down from where your stock cd player is cut a 3x3 hole, and where the shifter is set the h22 shifter plate there and cut away metal till it sits nice and flush and bolt that bad boy down,i will post pics tomarrow for you
Old Feb 17, 2003 | 11:48 PM
Kp_VtekNiks's Avatar
Default Re: h22 in ek (H22EK)
http://jdmshit.com has some good pics on there. thats what i looked off of to do my swap.
Old Feb 18, 2003 | 02:35 AM
junglerunna's Avatar
When my swap came in from hmo he sent me the shifter and the shift plate, but 2 of the black bushings that go on each corner of the shifter were missing, do i need to get 2 more of those or no? Because in some pictures i saw, no one used those black bushings that I am talking about, they just used a nut and some washers, so is that what i should do?
Old Feb 18, 2003 | 08:49 AM
H22EK's Avatar
Default Re: h22 in ek (junglerunna02)
i never use those bushings, it works just fine!
Old Feb 18, 2003 | 08:50 AM
H22EK's Avatar
Default Re: h22 in ek (Kp_VtekNiks)
the pictures of the linkage in the ek on JDMSHIT.COM are of my car!
Old Feb 18, 2003 | 01:17 PM
Wazup's Avatar
i dont see any pics on jdmshit.com.. just products
ajmj
Oct 14, 2009 10:06 AM
NICEHATCH
Feb 6, 2005 05:11 AM
BIGBLOCKEK
Nov 13, 2004 01:16 AM
mycro_machine
Apr 11, 2003 09:05 AM
