H22 eg help
Old Jun 3, 2002 | 12:19 PM
bw54867's Avatar
Default H22 eg help
What am I missing? The engine and tranny is a 2000 usdm h22.I plan on converting to obd1.
1.mount
2.intake,aem itr intake?
3.radiator,what year del sol radiator should I look for?
4.slim fan,what are my options?
5.axles,90 accord intermediate shaft,90-93 left+right integra axles? is 1990 the only year of accord shaft I can use?
6.distributor,what kind of distributor do I need?
7.wiring Harness.Will I need a wiring harness?
8.radiator Hoses,What kind?
9.alternator belt.
10.fuel Rail from a 90-93 accord.
11.92-95 egr valve and bracket.
12.92-95 civic dx map sensor and mount.
13.93-95 prelude vtec ecu
14.will I need new injectors and resistors when I convert the obd2 h22 to obd1? If so what are the specifics?
15.can I use the 5th gen shifter and cable or will I have to locate an older accord or prelude shifter and cable?
Old Jun 3, 2002 | 01:11 PM
Kamin's Avatar
Default Re: H22 eg help (bw54867)
https://honda-tech.com/zerosearch
Old Jun 3, 2002 | 06:08 PM
bw54867's Avatar
Default Re: H22 eg help (KAMiN)
anyone? not all the answers can be found by search
Old Jun 3, 2002 | 06:48 PM
DC5teg's Avatar
email this guy ==> lmartineziii@yahoo.com tell him jeremy sent ya...
Old Jun 4, 2002 | 06:40 AM
Jason kiDD's Avatar
1) HCP, Hasport, or Place Racing Mount kit
2) Any CAI for a Civic SI or short ram will do
3) 94+ Delsol or EX/SI radiator (Dual Core)
4) Flex-a-lite fan from Autozone or similar brand (12" worked for me)
5) I would just go with custom axles and save the hassle. Driveshaftshop or Raxxxles
6) You need a ODB I distributor/cap
7) You can modify the Civic harness to fit and just add Vtec sensor, Vtec solenoid, Knock Sensor, and O2 sensor wires
8) Lower from my 91 Accord worked for me, Upper 94+ Teg
9) You will need a shorter belt since there is no AC nor Powersteering Pulleys
10) Fuel rail from the Lude can be used
11) Should already be on engine
12) Still not too sure about this??
13) Correct there
14) If you want you can still keep your ODB II injectors and run them. If you decided to change to ODB I injectors then you will need a resistor pack.
15) Use the older Accord or Prelude shift lever and cable
Old Jun 4, 2002 | 06:37 PM
bw54867's Avatar
Default Re: H22 eg help (Jason kiDD)
Will I need to perform an internal coil conversion? What kind of distributor should I locate?
Old Jun 5, 2002 | 05:17 AM
Jason kiDD's Avatar
Distributor from a 92-95 lude will work.. However if your car is ODB II (96+) then you might have to switch to an external coil..
kasso
Nov 29, 2006 08:04 AM
zoomspeed05
Feb 19, 2006 11:04 PM
chidoks
Jul 18, 2003 10:26 AM
hydroflip
Dec 10, 2001 10:01 AM
HX_Guy
Jun 12, 2001 01:59 AM
