Fuel filter replacement
i will replace my fuel filter soon.anything i need to be aware of?
and the car is a eg hatch but i have a b16a engine swap.do i buy eg hatch fuel filter or gsr fuel filter becasue fuel filter is located on the firewall right?or is there a second fuel filter under body?
thanks. appreciate
Modified by crazyguy at 10:45 AM 8/20/2007
thanks. appreciate
Stouts 'n' Scotch
Re: Fuel filter replacement (crazyguy)
Just get one to match your vehicle. Make sure it comes with all new washers.
Other than that, it's a pretty straightforward procedure, just make sure you have rags around to catch the fuel that spills out.
No there isn't an underbody fuel filter just the one attached to the firewall. Just get the part for your original car, unless you wanted to upgrade to an aftermarket one like AEM with a replaceable element inside it. Technically there is also a filter bag on the inlet of your fuel pump but you gotta take the back seats out and get the pump out of the tank to service that thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by klungemonger »</TD></TR><TR><TD CLASS="quote">No there isn't an underbody fuel filter just the one attached to the firewall. Just get the part for your original car, unless you wanted to upgrade to an aftermarket one like AEM with a replaceable element inside it. Technically there is also a filter bag on the inlet of your fuel pump but you gotta take the back seats out and get the pump out of the tank to service that thing.</TD></TR></TABLE>
QFT
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">Just get one to match your vehicle. Make sure it comes with all new washers.
Other than that, it's a pretty straightforward procedure, just make sure you have rags around to catch the fuel that spills out.</TD></TR></TABLE>
QFT
Also make sure you open the gas cap to release fuel pressure in the lines, and crack the fuel line loose from the filter before unbolting it from the firewall.
QFT
QFT
Re: (spray_bombed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spray_bombed »</TD></TR><TR><TD CLASS="quote">be ready for it being tight man....tried everything on mine to get it loose...i finally just gave up and said f*ck it</TD></TR></TABLE>
true, sometimes its a pain to take it out.
Re: (spray_bombed)
thanks man.i will prepare for the worst
Re: (souljah_jon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by souljah_jon »</TD></TR><TR><TD CLASS="quote">did you have to change the lines also?</TD></TR></TABLE>
nope.just the filter itself.
