H22/Civic's with cold air intakes part 2
how did you keep your coolant reservoir in place with the intake there? i had to take the bracket off to get the intake on, then i tried to put the bracket back on, and there's no way it'll fit back on. the intake is in its way. what did u guys do?
Re: H22/Civic's with cold air intakes part 2 (Salvatore Leone)
The reservoir should still be able to fit in there just fine. Just make sure that the intake is not facing too far foward and position it in a place where it doesnt interfer with anything..
Re: H22/Civic's with cold air intakes part 2 (Jason kiDD)
lol the reservoir isn't going to fit in there the exact same way. It might fit, but not just like stock.
The diameter of the ITR intake is just too fat to fit both of those all the way in.....you're going to have to do some rigging to make it a safe fit. (reservoir not dangling around)
Re: H22/Civic's with cold air intakes part 2 (Jonathan_EH)
Like i showed you before I had no issues with reservoir not fitment. Only had to make a little bracket to hold it steady fromt the stock location..
hah, i just tied mine in place with some hose. looks ghetto, but gets the job done until i can make something that looks good and performs better.
but at the moment i have a lot more to worry about.
