H series motor and the front motor mount
When swapping a H series in a hatch/del sol/civic you only use 3 motor mounts... The tranny side, rear, and drivers side. However, when honda designed the prelude they chose to use 4 motor mounts. Tranny side, rear,drivers, and a front mount as well.
I am having a custom manifold made for my turbo setup and the front motor mount is somewhat in the way. So I was wondering if any of you guys knew if it is ok to remove it or not. Personally, I do not think thats the best idea in the world due to the load that will be put on the other 3 mounts as well as having a motor that will have over 350 ft lbs of torque to the wheels.
I can have the manifold redesigned and go with a top mount turbo instead, but I am curious as to if it is ok to ditch the front motor mount on a 4th gen prelude.
Thanks.
Thanks.
Re: H series motor and the front motor mount (PrecisionH23a)
i cut mine a bit. i hear the front motor mount is the weakest anyways.. im sure you also know that most hondas dont even have front motor mounts.
it might be worth checkin out what this guy did..
http://ludespeed.com/products/....html
hope it helps
hope it helps
