Obd2B to Obd2A conversion...?
Old May 27, 2007 | 09:43 PM
BoltonGSR's Avatar
Default Obd2B to Obd2A conversion...?
I have a 99 B20 in my 96 DC integra... i already have an obd2a ecu AND harness...
My B20 is obd2b and my car is obd2a
Is it possible to convert from obd2b to obd2a just by changing the distributor?
If no, what all do i need... any links??
Old May 27, 2007 | 11:33 PM
nokturnal_munkeeboy's Avatar
Default Re: Obd2B to Obd2A conversion...? (BoltonGSR)
use the obd2b to obd2a jump harness
Old May 28, 2007 | 09:49 AM
BoltonGSR's Avatar
Default Re: Obd2B to Obd2A conversion...? (nokturnal_munkeeboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nokturnal_munkeeboy &raquo;</TD></TR><TR><TD CLASS="quote">use the obd2b to obd2a jump harness
</TD></TR></TABLE>Isnt that only for the ecu to plug in? Im worried about the existing connectors in the engine bay...
Old May 28, 2007 | 09:52 AM
nutsack's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoltonGSR &raquo;</TD></TR><TR><TD CLASS="quote">I have a 99 B20 in my 96 DC integra... i already have an obd2a ecu AND harness...
If no, what all do i need... any links??</TD></TR></TABLE>
i don't think i understand, if your car is obd2a what is there to change? the harness on the motor should plug up to the harness in the car w/ no problems. you don't need to change distributors.
Old May 28, 2007 | 08:10 PM
BoltonGSR's Avatar
Default Re: Obd2B to Obd2A conversion...? (*******)
Im just wandering if all i have to do is change the dizzy on my obd2b motor cause my obd2a harness wont plug into the dizzy... What all do i have to do?
Old May 29, 2007 | 08:47 AM
BoltonGSR's Avatar
BUMP
Old May 29, 2007 | 10:01 AM
nutsack's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoltonGSR &raquo;</TD></TR><TR><TD CLASS="quote">Im just wandering if all i have to do is change the dizzy on my obd2b motor cause my obd2a harness wont plug into the dizzy... What all do i have to do?
yes, easiest thing to do would be to swap out the distributor. the crank angle sensor might not plug up either. another option is you could also use an obd2b (99-01) integra engine harness.
Old May 29, 2007 | 10:49 AM
BoltonGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ******* &raquo;</TD></TR><TR><TD CLASS="quote">
yes, easiest thing to do would be to swap out the distributor. the crank angle sensor might not plug up either. another option is you could also use an obd2b (99-01) integra engine harness.</TD></TR></TABLE>Crank angle sensor... I think i remember being told that one... Cant i just modify the harness?
What im really trying to find is someone who has done an obd2b engine in their obd2a car and what all i need to know before i do anything....
egmelo
10
Dec 13, 2007 10:04 PM
BoltonGSR
May 31, 2007 09:36 PM
BoltonGSR
May 23, 2007 07:59 AM
DevinW
Apr 7, 2003 10:29 AM
