whats needed for itr sway bar eg install
whats needed to use a gsr or type rear sway bar on a 95 eg si besides the beaks kit? also what can i do about the front sway bar?
Re: whats needed for itr sway bar eg install (speshuled619)
bump to the top.
i've got an ITR rear bar i'd like to see an answer to the ITR front bar
[Modified by dogpile5, 3:34 AM 8/6/2002]
Re: whats needed for itr sway bar eg install (dogpile5)
http://www.fastasknutz.com/team/just...ybar/index.htm
this is for a coupe.should be the same for eghatch??
Re: whats needed for itr sway bar eg install (TEAM JSJ)
so from that site that you linked it seems that i would also need gsr LCA's? I also noticed that the bottom rear tie bar was changed. the first one straight across and the one used at the end of the install had a bend to it. the last one seems to look like a neuspeed bar, is that the bar that i should also look into as far as lower tie bar because of its fitment?
so you have am itr bar in the rear? did you need anything besides the beaks kit? like new lca's ot anything?
If you want to use the ITR rear sway bar you will have to get the GSR LCA's because the enlinks connect to the arm.. Civic LCA's dont have this connection so therefore it wont work well..
If you want to still use the Civic LCA's then you have to invest in a Comptech kit that doubles with a rear tie bar or Suspension Techniques..
Re: whats needed for itr sway bar eg install (Jason kiDD)
do the lca's have to be from a gsr or can they be from an ls or rs integ? also what can i do about upgrading my front sway on my eg hatch?
They can be from any of those models that have rear sway bars. So I am sure that all of them should apply. Also you can get it from a SI Civic as well.
As for the front I have heard of people using the CTR front bar or the suspension techniques for the front as well..
dj theoretic
11
01-18-2009 11:49 AM
