GSR and ITR Crank......difference??
Old Sep 25, 2001 | 09:12 AM
Petah's Avatar
Default GSR and ITR Crank......difference??
I was told that the ITR ones are more balanced, is this true?? If so, what are the difference in the bottom end (block, rods) between the ITR and GSR? Thanks in advance!
Old Sep 25, 2001 | 09:39 AM
Trey's Avatar
25 Year Member
Default Re: GSR and ITR Crank......difference?? (eg-six)
They have the same rod stroke ratio but is counter weighted and balanced fromo what I've read. I have the ITR one and it's fine.
Old Sep 25, 2001 | 11:30 AM
rainforest's Avatar
Default Re: GSR and ITR Crank......difference?? (Trey)
your right.
Old Sep 25, 2001 | 11:35 AM
Petah's Avatar
Default Re: GSR and ITR Crank......difference?? (rainforest)
If i have the proper head work (valve springs, cams, retainers, etc), would it still be safe, using the GSR crank, to rev up to 9000 rpm without doing any work to the bottom end?
Old Sep 25, 2001 | 01:12 PM
Katman's Avatar
yes they are different..I have pics that show signifigant differences...
such as these:
ITR cranks have an emobossed 'R' on the actual crank itself and are wider on the counterweight fins.. when compared to the GSR crank..
Old Sep 25, 2001 | 01:37 PM
Lyonel's Avatar
Default Re: GSR and ITR Crank......difference?? (Katman)
Katman comes thru again!
Katman's Avatar
Default Re: GSR and ITR Crank......difference?? (Lyonel)
you know it!
Old Sep 25, 2001 | 03:37 PM
Petah's Avatar
Thanks Katman! But i guess there is still the question.......can i rev up to 9000 rpm using the stock GSR crank and rods?
Old Sep 25, 2001 | 03:50 PM
Katman's Avatar
personally I think you can....just as long as your valve train and powerband allow it.
Old Sep 25, 2001 | 05:56 PM
2080EK's Avatar
New User
Katman, Ken from Benen told me if i have any questions ask you on this board and so far i dont think you have let anyone down.
thats great knowledge! how did you learn so much man, ever work at a dealer or anything..... or was it just pure fun and ripping motors apart with friends
Old Sep 26, 2001 | 09:56 AM
Katman's Avatar
Default Re: GSR and ITR Crank......difference?? (FormNFunctionEK)
heh thanks..
I learned all of my Honda knowledge by trial and error...and yes by the pure fun of being curious about Honda parts...engines..etc with friends.
Old Sep 26, 2001 | 10:05 AM
3.3.3's Avatar
thats the learning process....trial & error & exploration
Old Sep 27, 2001 | 03:50 AM
Trey's Avatar
25 Year Member
Default Re: GSR and ITR Crank......difference?? (spnhb)
Nice pics KAT!!
Also, the rod and crank bearing guides are different, GSR uses ABCD and ITR uses TUVWXYZ. Kinda a PITA when you use the GSR rods on the ITR crank but plastigage will get you within tolerance.
Good Luck,
Mr HYDE
Dec 20, 2006 12:00 AM
Tech6023
Sep 21, 2005 09:15 PM
vtecmonster001
Feb 20, 2005 03:53 PM
vtecmonster001
Feb 14, 2005 04:34 AM
Odiedogcx
Oct 21, 2004 04:29 PM
