GSR B18C Clicking noise
Old 07-27-2006, 07:35 PM
street95civic's Avatar
Default GSR B18C Clicking noise
I have GSR motor swap into a civc and have not drive it for a year, now everytime i start the car theres a loud clicking noise coming from the engine. It will stop if i rev the engine a few time or after a few minutes of driving. Some people told me that because i dont have air condition, the A/C compressor is making the noise because its trying to run. Anyone have an idea?
Old 07-27-2006, 07:45 PM
wakeboard_dude5's Avatar
Default Re: GSR B18C Clicking noise (street95civic)
if it was the AC the clicking would come from there, not the engine. I would say change the oil and see how that goes. I always use Gunk's Motor Flush before i change my oil, just helps to clean out everything. If that doesn't help you may need to have your valve clearences checked. Hope this helps you out
Old 07-28-2006, 05:26 AM
Andres-eh2's Avatar
DONT NOT USE MOTOR FLUSHES EVER!!!!
This will damage your motor eventually. If you watch BestMotoring DVD VTEC club the guy from Spoon will tell you why. You loosen gunk that can get between bearings and throw off clearences on the motor.
Old 07-28-2006, 08:32 AM
DavidR's Avatar
Default Re: (Andres-eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">DONT NOT USE MOTOR FLUSHES EVER!!!!
If you've got gunk between your bearings, you've got bigger problems to worry about. I wouldn't use "flushes" for two reasons: 1. It may deteroriate the seals. 2. You can't ever get 100% of the "flush" out, so you'll always have "flush" left in the crankcase, at least, a little bit. It may cause harm over time. I guess DVDs is as just a good a source of reliable information as the 6 o'clock news, or the .... Internet! LOL. Hype.
Old 07-28-2006, 08:47 AM
Andres-eh2's Avatar
well at the end of the day it doesnt matter what i said as long as i mentioned that flushes are bad. I didnt quote exactly what he said on the DVD b/c i saw it a while ago but it was along those lines. Mr. Spoon must know i thing or two...
Old 07-28-2006, 11:18 AM
DavidR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">well at the end of the day it doesnt matter what i said as long as i mentioned that flushes are bad. I didnt quote exactly what he said on the DVD b/c i saw it a while ago but it was along those lines. Mr. Spoon must know i thing or two...</TD></TR></TABLE>
I was poking fun because you used that DVD as your reference, as if its a bible. He might know a thing or two, but, if things aren't translated correctly, or repeated correctly as he said them, thats how the minow turns into a 6ft shark (fish story).
Old 07-30-2006, 10:11 PM
:Andrew's Avatar
Default Re: (DavidR)
sounds like you might need to do a valve adjustment
Old 07-31-2006, 02:38 AM
Default Re: (:Andrew)
how do you do that? are you sure that's the problem?
Old 08-01-2006, 02:25 PM
:Andrew's Avatar
Default Re: (street95civic)
no not sure just a common noise. you could just need to do a oil change
Old 08-01-2006, 03:35 PM
I'm thinking it could be the clutch because the shop put in a new clutch. it clicks when I step on the clutch or play around with it. It was swapped from an automatic stock civic to a manual GSR. It makes small clicks and then all of a sudden it makes one loud one like a bolt is being shot all over the place inside the motor or something like that.
sirEGhatch
04-30-2014 09:41 AM
Nataku
10-05-2005 03:11 PM
mugen92acintls
08-24-2004 06:54 PM
rizen
09-30-2003 04:10 AM
Spaceman Spiff
05-29-2002 02:50 PM
Quick Reply: GSR B18C Clicking noise
