Overdrive pulleys
Overdrive pulleys
hey guys, need to know whether changing the alternator and power steering pulleys would result in any significant difference? i'm running a d16a6 btw. thanks.
Dont do it. Your alternator can get burnt out and your lights will dim at idle
I trust no after market pulley's except for the Fluidamper.
Aftermarket pullies are garbage!
* B A N N E D *
i disagree, you will get a significant difference on an H-series thats for sure, and how does an alternator blow out from driving slower than normal, the headlights may be dim though, that is correct.
make sure to call them underdrive pulleys from now on though.
1 Post
He's talking about the alternator and power steering pulleys not the crank pulley. But in a perfect setup the ECU should turn off the alternator and power steering really doesn't pull any power in a straight line anyway. I'd do the Power steering anyway as it might tighten the response. I'm partial to not having power steering at all though unless on bigger cars.
DC2*Integra
03-11-2006 12:52 PM
