grounding valve cover
Old Jan 13, 2004 | 11:51 AM
H22CL's Avatar
Default grounding valve cover
Does the valve cover have to be grounded? whats the reason? mines isn't grounded right now and car runs fine. just asking.
Old Jan 13, 2004 | 11:58 AM
Shadow Templar's Avatar
Default Re: grounding valve cover (H22CL)
It grounds off overall kinetic energy that builds up due to all the moving parts if i remember correctly.
Old Jan 13, 2004 | 09:14 PM
Slopoke's Avatar
Default Re: grounding valve cover (Shadow Templar)
It's not grounding your valve cover, its grounding your engine.
You should also have a ground running to your tranny.
You have alot of electrical components that use the engine as a ground. If Your engine is not grounded to your chassis(which is hooked to your neg. battery terminal), alot of your electrical compontents can be affected.
Your engine is probably running ok right now because all the current is running through your tranny ground, but is doing so less efficiently.
I actually helped a guy trouble shoot a "no start" today. The starter would just click and would not engage. After testing the battery, I noticed he had no engine or tranny ground.
I threw on an engine an tranny ground and it fired right up.
Grounds are important!
Old Jan 13, 2004 | 10:36 PM
Default Re: grounding valve cover (Slopoke)
In short, ground your damn engine!
Old Jan 14, 2004 | 03:58 AM
B18C2_sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke &raquo;</TD></TR><TR><TD CLASS="quote">It's not grounding your valve cover, its grounding your engine.
Grounds are important!</TD></TR></TABLE>
Well put. I could not have said it better.
Old Jan 14, 2004 | 07:37 AM
IS3Fifty's Avatar
Default Re: grounding valve cover (B18C2_sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C2_sedan &raquo;</TD></TR><TR><TD CLASS="quote">
Well put. I could not have said it better.</TD></TR></TABLE>
Same here, put it this way if your trying to look at it in laymens terms. You dont want positive and negative energies bumping heads. ground the *****..
Old Jan 15, 2004 | 04:02 PM
H22CL's Avatar
I'm gonna do it this weekend, I was just asking after I noticed people with engine grounds then looked at mines and didn't see any, the tranny is grounded though.
Old Jan 15, 2004 | 04:03 PM
B18bEK's Avatar
mines not correctly installed and i just get shocked everytime i get out of my car ... its annoying but so is taking the time to ground it right
Old Jan 15, 2004 | 04:06 PM
Kamin's Avatar
Default Re: (B18bEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18bEK &raquo;</TD></TR><TR><TD CLASS="quote">mines not correctly installed and i just get shocked everytime i get out of my car ... its annoying but so is taking the time to ground it right </TD></TR></TABLE>
lol yea all 30 seconds it takes is a real bitch...
ground your motor, it will run better.
shawn69
Apr 2, 2009 09:00 AM
Razr2
Oct 15, 2008 06:31 AM
ZippyZivic
Jun 16, 2007 02:23 PM
MadCityLude
Aug 23, 2006 10:11 PM
dingusjt
20
Mar 6, 2003 09:03 PM
