stainless steel lines & ends question
Old Nov 21, 2002 | 08:32 AM
Rob Dizzle's Avatar
Default stainless steel lines & ends question
I need a longer fuel line that goes from the fuel filter to the fuel rail
what ends will I need?
the guys here recomended these. but what size should i go with?
and use the teflon hose
http://www.racerpartswholesale.com/aero3.htm
i was going to re-use the factory ends brass ends and attach the hose the the brass ends
i figure this will cost me something in the 30 dollar range. i could just an itr fuel line, it will cost 55 from the dealer with my discount
btw, this is for a 95 gsr with skunk2 intake manifold. my intake piping will not fit with my stock fuel line
[Modified by Bob-DC2, 9:38 AM 11/21/2002]
Old Nov 21, 2002 | 10:07 AM
civbeater90's Avatar
Default Re: stainless steel lines & ends question (Bob-DC2)
ok are you going into your stock fuel rail or aftermrket?
Old Nov 21, 2002 | 10:21 AM
Flamenco-T's Avatar
Default Re: stainless steel lines & ends question (civbeater90)
you'll need 12x1.5mm to -6AN adapter, both males
then a -6 lines with both hose ends,
then a -6an to an O-ring boss thread fitting to your fuel rail...unless you;re running stock fuel rail....
Old Nov 21, 2002 | 12:25 PM
Rob Dizzle's Avatar
Default Re: stainless steel lines & ends question (Flamenco-T)
stock fuel rail
do i just hack off the banjo fittings on the fuel line?
Old Nov 21, 2002 | 01:57 PM
Smashback's Avatar
No, you take the stock line off and throw it away.
Stan, I thought the fittings needed were 12x1.25 not 12x1.5?
Kr4nG
Apr 10, 2009 12:48 PM
VspecSiR
Nov 25, 2004 01:48 PM
turbogsr13z
Mar 18, 2003 05:26 PM
Flamenco-T
Aug 4, 2002 04:57 PM
