Gauge cluster problem...
Old Aug 5, 2004 | 01:51 PM
krazy's Avatar
Default Gauge cluster problem...
my car has been sitting for a few months, and i just swapped in a jdm b16 into my del sol. anyway not too long ago i had to roll down the windows, and i had to hook the battery up. of course it was discharged, so i did it while i charged the batt. ANYWAY at that time, the windows worked, gauge cluster lit up (CEL, Malfunction indicators, etc) when i switched the key to ACC II....
so fast forward about 2 months, the swap is in, the car runs, BUT the gauge cluster only lights up the battery icon (alt), and the SRS indicator light when i start the car. shortly after, they turn off. Another thing is the windows do not work, and my blinkers dont work. BUT the hazrads work.
NOW, what could be the problem here? I mean i started the car fine, everything seems to be plugged in, and it all worked before. Any ideas? Im at a lost of clues. Ive done like 3-4 swaps before, and this has never happened. Thanks ahead of time.
btw: this is a JDM b16a in a 95 obd 1 sol.
krazy
Old Aug 6, 2004 | 12:56 PM
krazy's Avatar
Default Re: Gauge cluster problem... (krazy)
bump!
Old Aug 6, 2004 | 12:59 PM
Adam.'s Avatar
This may seem obvious, but have you checked your fuses?
Old Aug 6, 2004 | 01:02 PM
krazy's Avatar
Default Re: Gauge cluster problem... (DarkKnight[DMD])
yea, that was the first thing i checked. all good.
krazy
Old Aug 8, 2004 | 08:35 PM
RICE POLICE SIP's Avatar
as for the windows, did you check your window lock?
boosted_ejcivic
Honda S2000
Sep 1, 2015 12:57 PM
Supremee
Feb 21, 2008 09:35 PM
ltran82
Nov 1, 2007 12:58 PM
krazy
Aug 6, 2004 02:36 PM
