Fuel Pump ? How to physically tell the difference?
Old Aug 14, 2003 | 11:57 PM
muse's Avatar
Default Fuel Pump ? How to physically tell the difference?
So far, I've gathered the following:
The GSR, ITR, and Civic Si all flow higher gph than ls and sohc fuel pumps, correct?
Now, if you purchase a pump from someone, how do you physically tell you are getting an ITR or GSR or Civic Si, not a civic or integra ls? Will the pump have a part# or marking on it?
I'm really curious, I have a pump that is supposed to be GSR but I am having doubts.
anyone have pics or ideas?
Old Aug 15, 2003 | 04:50 AM
VTECVillain's Avatar
Default Re: Fuel Pump ? How to physically tell the difference? (muse)
Good question as I have yet to be able to tell them apart unless they are still attached to the base mount (which could still be switched). I have a 99 GSR pump in my 92 VX which came straight from the GSR because I took it out myself I've had that pump, my stock VX, a 90 CRX Si and a 91 CRX DX all side by side and there were no significant marking to tell them apart.
Old Aug 15, 2003 | 11:11 AM
muse's Avatar
Default Re: Fuel Pump ? How to physically tell the difference? (VTECVillain)
well ****. What about the base mount, is there anything significant other than shape to tell the two apart? i know you have said the 92-95civ base mount was different than the 94+integ because it wont drop right in, but is the 96-00civ base mount the same as a 94+integ?
thanks for the help villain, you tha mang...
092eg6
May 8, 2010 05:52 PM
White98LS
May 29, 2007 11:07 AM
Fuster_Cluck
Mar 24, 2003 08:09 AM
xhatchracerx
Feb 4, 2003 01:27 PM
TurboT
May 9, 2002 07:28 AM
