fuel pump question...
searched but i couldn't find a definite answer. just swapped a b16 into my ek hatch...the stock fuel pump is obviously working bt would it be worth it to swap in the one from an 00-99si? will i notice a difference?
Re: fuel pump question... (nY's FiNeSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nY's FiNeSt »</TD></TR><TR><TD CLASS="quote">i have a b18b and i'm going to put a gsr fuel pump in within the next few days, the old one is dying = (</TD></TR></TABLE>
unless it's ls/vtec or your building your motor or it's FI, i wouldn't. stock b18b's run 79lph. just like sohc motors.
Re: fuel pump question... (2000CX)
i have a 97 hatch with a b series swap and changed out my fuel pump a couple weeks ago from the stock dx to an itr. i felt a difference, the car didn't lag as much and it runs smoother throughout the whole powerband
definitely swapping the fuel pump is a good idea.
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000CX »</TD></TR><TR><TD CLASS="quote">i got my motor from IAS...so it came with the pump from the motor! i will install it as soon as i have time. thanks all!</TD></TR></TABLE>
i wouldnt use a used fuel pump. but thats my opp. for the money you spend on a stock one, a walbro will do you much better.
Go ahead and use the fuel pump that was supplied with the swap from IAS. IAS provides very clean and reliable swaps.. The pump IAS supplied should work fine..
Re: fuel pump question... (00MRSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00MRSi »</TD></TR><TR><TD CLASS="quote">Go ahead and use the fuel pump that was supplied with the swap from IAS. IAS provides very clean and reliable swaps.. The pump IAS supplied should work fine.. </TD></TR></TABLE>
thats how i feel...i guess i will just cross my fingers and throw it in!
