Engine Temp Guage is stuck on HOT!!
Old Apr 3, 2003 | 12:12 PM
CM-R's Avatar
Default Engine Temp Guage is stuck on HOT!!
My engine temp gauge is shooting up to hot even though my engine is completely cold...Is there a senor on the engine some where i can look at to see if it is loose or is my Si gauge acting up? This is happening to my 96 EK hatch with a 99/00 SI gauge cluster.....i have a 96 EK with a 96 GSR motor and 99 SI gauge cluster
[Modified by CM-R, 1:12 PM 4/3/2003]
Old Apr 3, 2003 | 12:38 PM
Newman's Avatar
New User
Default Re: Engine Temp Guage is stuck on HOT!! (CM-R)
Check your thermostat. Might be stuck closed, thus causing your engine to overheat. Eitherway, take it out and try driving the car.... if your temp stays down, then you know you need to replace the thermostat. If not, and you still have the same problem, then it's something else but you've at least taken away the most common problem out of the equation. BTW, driving w/out the thermostat won't hurt anything... just takes the car longer to warm up.
Old Apr 3, 2003 | 02:55 PM
Kataku2K3's Avatar
Default Re: Engine Temp Guage is stuck on HOT!! (Newman)
Personally I don't think this is the problem if it tachs your gauge even when you initially start the motor... I would check the resistance over the ECT gauge on the head... I'm pretty much willing to bet that you read zero ohms over it... It would be the same as if you straight grounded the wire going to the ECTG... NO resistance ='s HOT on the gauge... If this is the case get a new ECTG and you'll be set... If it checks out good then see if you're ECTG wire is shorting/grounding off somewhere... Easiest way to do this is to check for continuity from the ECU pinout over ground... It's as simple as that... If you need anything else let me know... Peace
Old Apr 3, 2003 | 11:17 PM
CM-R's Avatar
Default Re: Engine Temp Guage is stuck on HOT!! (Kataku2K3)
Can you please show me or explain to me in detail how the gauge or plug looks like so i can check it out? Thanks alot for the help
[Modified by CM-R, 12:18 AM 4/4/2003]
Old Apr 4, 2003 | 12:33 AM
Kataku2K3's Avatar
It's like 1:32am right now but i'll take a pic sometime later today when I wake up to show ya what to test over... Peace
Old Apr 7, 2003 | 09:15 PM
CM-R's Avatar
Thanks alot for the help the pics would help me a lot
CivicMatt94
Jul 21, 2014 08:33 PM
nz_mike
Aug 24, 2007 02:54 PM
electric-boost
Dec 11, 2006 08:37 PM
CM-R
Apr 2, 2003 12:56 PM
Cosworth
Jun 15, 2001 12:04 PM
