engine Swapping
Old Mar 24, 2005 | 09:27 PM
^AnDre^'s Avatar
Default engine Swapping
Ive got a 90 civic dx with a b18b right now in it.. looking to do an engine swap... i use the car only for solo 1 and regional racing.
ive been thinking bout a b18c5 swap or a b18c1 swap... but was also wondering if anyone has ever put a k20 into a 89 dx ?.. does it fit first of all, second what does the weight differ from the b18c5 to the k20 as well how much would the install be?
i need something with lots of torque to get me outta the turns nice and fast.. k20 would be ideal but i know the swap hasnt been done too often.
give me some feedback please...and help too...
Old Mar 24, 2005 | 10:32 PM
Redline130's Avatar
Default Re: engine Swapping (^AnDre^)
If you are looking for torque, have you considered a B20B? Might be a little less damaging on the wallet than a K20 swap, unless money isn't an issue.
Old Mar 25, 2005 | 09:13 AM
^AnDre^'s Avatar
Default Re: engine Swapping (Redline130)
whats the stats on the b20b ? ... how much more/less does it weigh than a b18c5 ?
Old Mar 25, 2005 | 09:17 AM
^AnDre^'s Avatar
acutally, what about the b20z ?... is it any good ?... reliable?... swapable?.... weight?
Old Mar 25, 2005 | 12:16 PM
IHateJDM's Avatar
you have a b18b already, what's wrong with that block? get a gsr or b16 head and a golden eagle vtec conversion kit. Search for ls/vtec. Good hp and torque real cheap.
Old Mar 26, 2005 | 04:12 AM
^AnDre^'s Avatar
Default Re: engine Swapping (IHateJDM)
the block has 80,000 kms on it... and has been used in my race car for probally 3 years now, i am not to sure on its stability, i would not want to sink a bit of money into it only to find it blow up in my face.
what kind of gains can i expect from a ls/vtec swap ?
also what would be a good set of pistons and cams to go with for a track set up... min octane used is 94 and the car is not used on the street period.
Old Mar 26, 2005 | 04:26 AM
^AnDre^'s Avatar
with the ls/vtec swap, would it be wise, or has anyone done this, boring out the block to 2.0L for the added torque? is this reliable? worth the time and money ?
Old Mar 28, 2005 | 04:43 PM
supercharged18g's Avatar
ls/vtec your looking about 180-195hp,dont bore the b20, the cylinder walls are already thin
Old Apr 2, 2005 | 07:21 AM
^AnDre^'s Avatar
Default Re: engine Swapping (supercharged18g)
is that 185-195 on a b18b or a b20 ?
MattSaults
Jun 25, 2015 03:30 AM
MattSaults
Jun 23, 2015 06:30 PM
eweimert
12
Jan 29, 2008 08:18 PM
DXRiCE98
Apr 2, 2003 01:22 PM
volleyd13
Dec 30, 2002 03:34 PM
