Poly mount inserts
Poly mount inserts
Ok, sorry the search function is messed up, and i know there was a thread on this a while ago.
Ok, im about to swap my motor to a b16 (i have a 97 ex) And from what people have said, adding inserts later is a pain in the ***, so i was going to do it while i had the motor out.
My question is, Prothane or ES? and also with these kits are ALL of the mounts taken care of? Will i need any other mounts? and do i buy them for the 99-00 si? or are they done by like the engine?
Re: Poly mount inserts (BigZ88)
buy the mounts for the motor you are putting in. i'd order the inserts from prothane for an si.
the rear tranny t bracket bushing should be the same on the two cars.
i know on the eg if you have an automatic the rear mount is different from the manual cars, and it is different from the integra also.
I'd get part numbers for your car and the car your motor came out of to double check everything will go in.
Re: Poly mount inserts (Bumnah)
yea i had to cut one of my mounts to get it to fit into the engine mount on my 97 dx, then took a zip tie and looped it through to tighten it in there, tranny mount since i couldnt find ones for an auto just bought the manual ones. i got the poly ones, work good
Re: Poly mount inserts (97hb)
ok, i know for a fact there are people out there that have these in their car.... here is a link for 99-00 Si
http://www.parts123.com/PartFrame.as...Phil's_Inc
okay I am not really following this post...
but I got some tranny mount inserts from summit. you can really feel the engine, but my motor mount did end up busting? crap! don't now b/c of that.
terminaloverlowd
10
06-07-2004 09:15 PM
