Engine Code 91.
Old Oct 13, 2003 | 11:07 AM
Jinxed's Avatar
Default Engine Code 91.
Hi guys,
I need help.
I just put a 97 B18B motor & ecu into a 97 civic cx.
i used the stock civic harness,
did the iacv fix &
wired in the different plugs correctly (alternator, crank fluctuation sensor ect.).
The motor runs strong but,
i'm getting code 91 which is tank pressure.
I'm lost & have no idea what to do.
I've done my research &
never heard about any other changes that need to be done to the wiring other than what i mentioned earlier.
Does anyone have any ideas?
Thanks,
JAY.
Old Oct 15, 2003 | 02:38 AM
97hb's Avatar
Default Re: Engine Code 91. (Jinxed)
Gotta love code "91" The fix is to get an 96-00 EX gas tank with the pressure sensor in it(you could probably get the sensor and weld it in, but I do not know how reliable it would be, plus welding a gas tank . Next think is to get the charcol canister with the purge soliniod on it. Wire it all to the ecu and you should never have the code again. I have also heard 96 ecus did not have code "91". Another way to get rid of the code is to go OBD1.
Old Oct 15, 2003 | 06:20 AM
Trey's Avatar
25 Year Member
Default Re: Engine Code 91. (97hb)
OR the easier "work around" is to turn the key to the accessory position (don't start the car) and count to 10. Then start the car.
That lets the fuel pump pressurize the system and the code won't come on.
I only got the code when I ran a USDM ECU and the car sat for long periods of time like overnight.
Old Oct 18, 2003 | 04:30 PM
97hb's Avatar
Default Re: Engine Code 91. (Trey)
I always let the fuel pump prime and still get the code.
mugenboi
Nov 2, 2007 05:12 AM
Jinxed
Oct 13, 2003 06:22 PM
UdontknowME
Jul 7, 2003 09:45 PM
97CivicTypeR
Feb 25, 2003 08:17 PM
97CivicTypeR
Feb 24, 2003 10:37 PM
