HELP CODE 91???
Old Jul 6, 2003 | 11:21 PM
UdontknowME's Avatar
Default HELP CODE 91???
yeah i got aOBD2 96 civic hatchback and i just installed a 98 LS OBD2 engine in my car..next thing you know in a couple weeks check engine light comes on and i got a code 91??something with the fuel pump..if you guys can help a fellow h-t member that would be ..again thanks in advance!!
Old Jul 7, 2003 | 12:39 AM
HYBRID_H@TCH's Avatar
Default Re: HELP CODE 91??? (fork sports)
check your gas cap..if thats not it check your vac hose's going to the canister on the firewall near the battery.
Old Jul 7, 2003 | 03:29 AM
97hb's Avatar
You will need a gas tank with a pressure sensor built in (ex gas tank). You will also need a charcol canister with a purge release as ours don't have the purge solinoid. Wire it up and you should not have any problems. I just run with the code on. Too much damn trouble. You could also just go obd2-obd1 and get rid of the code that way. I have also heard 96 ECUs don't have this code, but could be wrong. I know for a fact the obd1 dont have that code
Old Jul 7, 2003 | 11:22 AM
Default Re: HELP CODE 91??? (97hb)
96 and up have the tank with the sensor.....most of the time its a leak in the vac lines going to and from the canister
Old Jul 7, 2003 | 04:45 PM
97hb's Avatar
Default Re: HELP CODE 91??? (99Hybrid_Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Hybrid_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">96 and up have the tank with the sensor.....most of the time its a leak in the vac lines going to and from the canister</TD></TR></TABLE>
96 and up EX have the sensor. The 96-98 dx,cx do not have the sensor. The 99- dx,cx have the sensor.
Old Jul 7, 2003 | 06:03 PM
so is it okay to drive around wit tha check engine light on??wat do u guys suggest me to do??THANKS!!
Old Jul 7, 2003 | 07:46 PM
97hb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fork sports &raquo;</TD></TR><TR><TD CLASS="quote">so is it okay to drive around wit tha check engine light on??wat do u guys suggest me to do??THANKS!!</TD></TR></TABLE>
Well in Texas they do a obd2 test for the emissions. All I do is clear the code before they hook the scanner in and it tests all the sensors. The emission evaporative system comes up not ready but I have still passed 2 years in a row with this method. Don't know about your state. I have been driving on this code for 2 years now with no adverse affects.
Old Jul 7, 2003 | 09:45 PM
alright thanks alot 97 hb!!
blacktibby07
Mar 8, 2011 08:01 AM
xtn5021
Sep 22, 2009 06:21 PM
boiek9
Jun 17, 2005 05:57 PM
BlackGser
Apr 23, 2005 03:45 PM
boiek9
Sep 13, 2004 01:42 PM
