EF Hydro B-Series Axle Question????
I searched but could not find it. I need to know which axles are used. I am building up a drag crx and hydro trannys are a lot easier to find parts on. I used a hasport billet kit and modified the tranny mount so it can fit the hydro tranny but I need to know which axles will fit. I have someone that has the driveshaftshop stage II axles for a 94+GSR w/abs and I need to know if those will fit. Please help me out.
Thanks in advance,
Daniel
Thanks in advance,
Daniel
Re: EF Hydro B-Series Axle Question???? (dkim48)
any integra axles will fit, just remove the outer dust rings on the hubs and axles and match the halfshaft with the axles. a 94+ setup will be fine
Re: EF Hydro B-Series Axle Question???? (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">any integra axles will fit, just remove the outer dust rings on the hubs and axles and match the halfshaft with the axles. a 94+ setup will be fine</TD></TR></TABLE>
Bringin it back from the dead. Thanks bro, its been a while now but I finally got everything together(94+Setup).
VtecKiDD
12-29-2005 09:45 AM
