ECU question
I have a 99 Civic Lx with a 99-2000 Civic Si wiring harness I just purchased a 92-95 JDM b16a from HMotorsonline.com and was curious if I can use a 94-95 GSR ecu for my car I already have the obdII to OBDI conversion harness. The B16 is going to be used with my GSR transmission..
any help would be great
Carlton
Modified by QUICKERSILV3R at 1:13 AM 1/31/2006
Carlton
I think that if you used the gsr ecu it would throw a cel because your b16 doesn't have intake butterfly's and I think gsr's have egr valves but i might be wrong about that. anothing thing is make sure your jumper harness is obdIIb to obdI.
you can use a P72 ecu on a B16A engine. You will NOT get a check engine light for the IAB's, but the downside is that VTEC will kick on at 4400-4500rpm which is a bit early....hence the boggyness. You could have the P72 reprogrammed with a P30 map though..
