which ecu???
im gonna do the h22 swap into my ek hatch. should i go with the gsr ecu or the chipped stock????
Re: which ecu??? (h22dx)
chipped P28.
Re: which ecu??? (Peagreenhatch)
the mugen chip i can redline at 9200!! will i need to upgrade anything else for this?? like fuel injectorsor anything? that would big big ass power!!
no, not a mugen program.
get the STOCK h22 program or get an OBD2/1 (if you are converting) h22 prelude ecu. you have no need for a mugen program. and just because you could rev that high dosent mean you will make power. you would need cams, valves, valve springs, retainers and some tuning for 9200rpms. just get the stock ecu/program for the h22. [Modified by Kamin, 1:24 AM 1/9/2003] |
OBDI P13 with a Spoon or stock program best there is. second best is a GSR ECU + VAFC, then chipped P28.
Re: which ecu??? (eg6ajk)
so get a spoon chip for the stock obd 1? can i put that in myself? what will the chip do?
no
not a spoon chip let me explain somthing, those chips are for modified cars, higher revlimit, diffrent vtec crossover, etc you have a BONE STOCK motor. you need the BONE STOCK ecu. get the prelude ecu. and chipping an ecu cant be done by yourself unless you have a rom writer and the entire program. |
Re: which ecu??? (Kamin)
no not a spoon chip let me explain somthing, those chips are for modified cars, higher revlimit, diffrent vtec crossover, etc you have a BONE STOCK motor. you need the BONE STOCK ecu. get the prelude ecu. and chipping an ecu cant be done by yourself unless you have a rom writer and the entire program. I offer DIY kits for $39 shipped which require you to solder in new parts. thats all. |
