Dome height same as Piston-to-Deck Height??
Sushi Buffet Champion
I have a set of JE pistons and the box says that the Dome height is 0.05. I'm using the C-speedracing compression calculator to determine my compression. So my question is what's the dome height? Is it the same as the "piston to deck height? Also the box says that the compression distance is 1.181, where do I punch these numbers into the C-speedracing calculator? Piston displacement is -1.7cc.
http://www.c-speedracing.com/howto/c...c/compcalc.php
Please help my out. It's a B20 block with B16 head and 85mm pistons. Can someone help me figure this out? Thanks.
[Modified by GapxGuy, 4:43 PM 12/21/2002]
With that calculator...
For the pistons click "other", than type in your piston displacement
For everything else, just use the type of parts you are using.
Block: B20B/Z but change the bore to 85 mm
Head: B16A
etc
etc
Head: B16A
etc
etc
So what about the "piston-to-deck-height" at the bottom? Do I just use the stock number? Or does it has something to do with the piston specs?
When the piston is at TDC it should be .030" below the top of the block or deck, I think thats what piston to deck height is, but am not 100% sure.
The chart you have highlighted is the cylinder head volume, like if you turned the head up side down and filled up one of the combustion chambers with water, it would hold 38.6 cc's
I think it is dependant on the crankshaft (stroke) and the con-rod length. So I think it's dependant on the block. Hopefully someone else with more technical knowledge will chime in
GapxGuy
13
Apr 23, 2004 11:24 AM
ihaterice
Nov 29, 2003 11:52 PM
