cp piston selection, seriously
Old Sep 25, 2010 | 07:53 PM
Spawne32's Avatar
Default cp piston selection, seriously
why cant they make this a little easier...
got a B18b1, wanna bore the block out to 84mm for 2.0L like a b20, i wanna use CP pistons, and i wanna get about 10:1 compression, CP doesnt make 10:1 compression b series pistons....and the 9.7:1 compression pistons they make the compression they list, apparently is for a b series with a b16a1 head attached, according to the legend at the bottom. Now i know we have to account for things like decking the block and head, and the overbore going from 81 to 84mm will loose compression. Can someone help me with my selection here.
Old Sep 25, 2010 | 09:24 PM
EG1834's Avatar
Default Re: cp piston selection, seriously
Now I may be mistaken, but it looks to me that if it has the number 4 under notes, it will work with a B18A/B head.
SC7017 looks like it's an 84mm bore piston that can get you close and work with a B18A/B head. I would try to find out what the dome volume is on those pistons so you can figure out what the compression ratio will really be.
Old Sep 25, 2010 | 09:26 PM
Spawne32's Avatar
yeh i figured out that much, but i dont understand why the compression is based off of using a different head on every b series block, im assuming that the b16 head has a lower height which raises the compression, so the estimate they are giving is for the maximum available compression the piston gives?
Old Sep 25, 2010 | 09:39 PM
EG1834's Avatar
Why assume? If you find out the chamber volume of your head vs. the B16A, you should be able to figure out what the CR will be on your engine. Here are the formulae to figure it all out. The measurements (bore/stroke/etc) are meant to be in inches, not millimeters.
Swept: bore^2 x stroke x .7854 x 16.39 = cc’s
Head Gasket: bore^2 x crushed thickness x .7854 x 16.39 = cc’s
Deck Clearance: bore^2 x distance in(+) or out(-) of the hole x .7854 x 16.39 = cc’s
Piston: Measured Dish(+) or Dome(-) in cc's
Combustion Chamber: Measured in cc's
Old Sep 25, 2010 | 09:43 PM
Spawne32's Avatar
yeh ill take a look at that tomorrow after i get some sleep lol cus right now it looks like its written in chinese at 2am
Old Sep 26, 2010 | 02:14 AM
SD_Lurker's Avatar
HT White Ops
You are sleeving the block, right?
Old Sep 26, 2010 | 06:58 AM
Spawne32's Avatar
more then likely yes
Old Sep 26, 2010 | 10:38 AM
narfdanarf's Avatar
b16 head will give you lower compression. So if you're using a gsr head with those same pistons you will be more like 10:1
Old Sep 26, 2010 | 10:45 AM
Spawne32's Avatar
ill be using a b18b1 head
2kdrift
Aug 18, 2015 06:51 PM
Too-R3ckl3ss
Apr 1, 2012 12:21 PM
HellaFab
11
Jul 13, 2011 11:51 PM
blazzer
11
Jun 17, 2011 10:24 AM
stealth50k
Jul 6, 2008 01:13 AM
