Dome height same as Piston-to-Deck Height??
I have a set of JE pistons and the box says that the Dome height is 0.05. I'm using the C-speedracing compression calculator to determine my compression. So my question is what's the dome height? Is it the same as the "piston to deck height? Also the box says that the compression distance is 1.181, where do I punch these numbers into the C-speedracing calculator? Piston displacement is -1.7cc.
http://www.c-speedracing.com/howto/c...c/compcalc.php Please help my out. It's a B20 block with B16 head and 85mm pistons. Can someone help me figure this out? Thanks. [Modified by GapxGuy, 4:43 PM 12/21/2002] |
Re: Dome height same as Piston-to-Deck Height?? (GapxGuy)
With that calculator...
For the pistons click "other", than type in your piston displacement For everything else, just use the type of parts you are using. Block: B20B/Z but change the bore to 85 mm Head: B16A etc etc |
Re: Dome height same as Piston-to-Deck Height?? (xThexHeadx)
So what about the "piston-to-deck-height" at the bottom? Do I just use the stock number? Or does it has something to do with the piston specs?
When the piston is at TDC it should be .030" below the top of the block or deck, I think thats what piston to deck height is, but am not 100% sure.
The chart you have highlighted is the cylinder head volume, like if you turned the head up side down and filled up one of the combustion chambers with water, it would hold 38.6 cc's |
When the piston is at TDC it should be .030" below the top of the block or deck, I think thats what piston to deck height is, but am not 100% sure. |
I think it is dependant on the crankshaft (stroke) and the con-rod length. So I think it's dependant on the block. Hopefully someone else with more technical knowledge will chime in
ttt
