Are D-series and B-series Slave cylinders the same? Swap question!!!!
I need to know if the slave cylinder from a 92 civic vx is the same thing as a 94-up integra slave cylinder? The reason I ask is because I just put a b17 into my 92 hatch and the cluthc is not fully disengaging. When the car is turned off, the transmission lets you shift smoothly throught all the gears. When you turn the car on none of the gears are available. If you put the car in gear while the engine is off, then start it it will jump either forward or back depending on the gear. Is it my slave cylinder.
Re: Are D-series and B-series Slave cylinders the same? Swap question!!!! (92tealvx)
The slave cylinders are the same. I swapped a 96 B18C into my friends 95 DX coupe and used the slave cylinder from the DX tranny. Funny thing is he is experiencing the same problem as you but it worked perfectly for about a week then started getting hard to shift.
I replaced the salve cylinder for the same reason but it never fixed the problem. We have tried everything possible without taking the tranny off. I'm not sure what the problem is but we are going to take the tranny off and see if there is a problem with the throwout bearing or clutch.
Re: Are D-series and B-series Slave cylinders the same? Swap question!!!! (owen_the_soyboy)
did you bleed the lines from the slave cylinder? its not 100% necessary but its a good idea.
Re: Are D-series and B-series Slave cylinders the same? Swap question!!!! (Kamin)
The clutch pedal adjustment and pressure is fine. The slave cylinder works for sure and the line was fully bled after installing the new slave cylinder. There is something that is not allowing the clutch to disengage. I'm assuming it's engaged and stuck there.
With the car off you can shift though all the gears but with the car running it will not go into gear at all like something is blocking it from allowing you to shift. If you put the car in gear with the pedal pressed fully in then start the car it will jump and die like you don't have the pedal pressed in at all.
I know it sounds like the salve cylinder would be to blame but I can't see how it would be. The pedal pressure is solid and if I slide the rubber boot back you can see the rod move back and forth when the pedal is pressed in and out.
Re: Are D-series and B-series Slave cylinders the same? Swap question!!!! (VTECVillain)
I ran into this problem when i did a 94 b18c1 into a 93 hatch. I asked my friend if he wanted me to pull the tranny off before i put the swap in and he declined. well after the swap was in, I had the same problem you r describing. I tried everything, and then finally I pulled the tranny off and found out half the "fingers" on the pressure plate were bent in and the press. plate was stuck to the clutch.
[Modified by jmm96gsr, 10:11 AM 2/26/2003]
I am working on the car with 92tealvx. The reason why we ask if the slave cylinders are the same is because of the different clutches used in b and d-series engines. Since we are using a civic vx slave cylinder on a b-series transmission and clutch, could it be possible the civic slave cylinder dosent have a long enough throw to disengage the clutch from the flywheel completely? I think it would make sense, but im not sure. Also, we are using a 92 B17 clutch in a 99 GS-R Tranny. Could it be possible the clutch is coming into contact with the bellhousing making it impossible for it to fully disengage? Thanks in advance for the help
Modified by 92tealTSI at 9:12 PM 10/12/2003
Re: Are D-series and B-series Slave cylinders the same? Swap question!!!! (92tealTSI)
i used my dx slave cylinder when i put a b16 in my car and it works find...so i dont think that makes a difference...but i took the tranny off and replaced the clutch with a new one, the old clutch was fried...
[Modified by sir2chad, 7:40 PM 2/26/2003]
Re: Are D-series and B-series Slave cylinders the same? Swap question!!!! (sir2chad)
Does anyone know whether a b17 clutch will work in a 99 gsr tranny? That may be the problem
Modified by 2muchPSI at 7:07 PM 10/11/2003
Does anyone know whether a b17 clutch will work in a 96 gsr tranny? That may be the problem
r1de4life
11-19-2006 06:36 AM
