CR-VTEC
Old Sep 16, 2001 | 10:05 PM
cdmg's Avatar
New User
Default CR-VTEC
Does anyone have info. on this conversion. What is the Max Hp, etc.? What about reliability?
Old Sep 17, 2001 | 06:33 PM
navin's Avatar
Default Re: CR-VTEC (cdmg)
TTT id like to know too
Old Sep 17, 2001 | 07:22 PM
rainforest's Avatar
Default Re: CR-VTEC (navin)
http://www.crvtec.com http://www.b-20.net
have fun
Old Sep 18, 2001 | 07:56 AM
3.3.3's Avatar
Default Re: CR-VTEC (rainforest)
dont expect to be revving to 8-9k....torque is yummmmyyyyy!!!!
Old Sep 18, 2001 | 05:54 PM
jimbob's Avatar
New User
Default Re: CR-VTEC (spnhb)
8-9k revving should be fine for the CRVTEC. Still keeps a similar bore/stroke ratio as an ITR. But doing it is probably not a good idea unless you plan to build it for drag and just worry about how much power you can squeeze out of the engine.
Old Sep 19, 2001 | 07:32 AM
b20b's Avatar
New User
Default Re: CR-VTEC (jimbob)
I ran mine to 8 grand daily for about 4 months no problems. Just finished my rebuild to go to 9500. can't wait.
Old Sep 19, 2001 | 03:54 PM
mannyman's Avatar
El Veterano de Sur Califas
Default Re: CR-VTEC (b20b)
was that on stock rods???? or aftermarket rods?
Old Sep 20, 2001 | 05:22 AM
b20b's Avatar
New User
Default Re: CR-VTEC (mannyman)
stock rods. People told me that it wasn't a good idea, but man, you can't resist pushing the motor up there. I did it a couple times and the engine still sounded good. So I pushed it as much as I wanted till about a month ago. Just finishing the rebuild now. And I did not rebuild it for damaged reasons. Just wanted more power.
Old Sep 20, 2001 | 10:25 AM
HXMan's Avatar
What kind of shape was the motor internals in? Cylinder walls? Crank?
Old Sep 20, 2001 | 11:57 AM
jg's Avatar
jg
try doing some searching. This has been covered. For hp figures go to http://www.importreview.com Although they don't tell exactly what the compression is on some of the set-ups.
Old Sep 20, 2001 | 02:42 PM
mannyman's Avatar
Default Re: CR-VTEC (jg)
hell yeah thats what i wanted to hear!! My friend tells me that the stock rods should be ok, and a local shop also said that the stock rods can take a beating. I am in the middle of putting my crvtec together, it should be rolling by this weekend....or maybe next one. I went ahead and got some 10.5 je pistons .40 over, because later on down the line i will get a 100 shot of nos!! i have a gsr head which will go on aswell. What did you do to your block?? I was going to get some eagle rods, but my friend said that i better upgrade my valvetrain with titanium ****. He said that when i squeeze it will be too much heat and will cause my valvetrain to fail. So im saving for that ****, and eventually i will break my **** down again and through some rods in their, like you. later
manny
Old Sep 20, 2001 | 06:10 PM
ImportReview
Guest
Posts: n/a
Default BOOYAH
i would say, a fully built, all options CRV VTEC resides in the 220-240 wheel horsepower range depending on compression.
This one is about 12.7:1.
It beats some motorcycles on the street. Its fast.
Stevenpace
Jun 23, 2013 09:10 AM
Cynical 1
Feb 8, 2012 01:31 AM
nickgmiller04
May 10, 2004 05:48 PM
LAKER HATER
Mar 31, 2004 09:06 AM
B18C GSR CIVIC
Oct 23, 2003 07:21 PM
