what is the purpose of shotpeening?
Old Mar 30, 2004 | 08:29 AM
LAKER HATER's Avatar
Default what is the purpose of shotpeening?
what exactly is the purpose of shotpeening and what is shotpeened in the process? i am still learning.
Old Mar 30, 2004 | 08:39 AM
Burke's Avatar
Banned
Default Re: what is the purpose of shotpeening? (lsturbo707)
to increase the residual stress in the rods.
its makes them stronger
Old Mar 30, 2004 | 08:47 AM
Turbo E's Avatar
removes stress risers (where things crack) and "massages" the grin of the metal making it more flexable and less likely to fail horribly.
kinda like a poor mans forging.
EDIT: shot peening is firing ball berings at a part, ike sand blasting.
Old Mar 30, 2004 | 06:47 PM
so shotpeening would be a good idea to do if rebuilding a motor with new stock rods or used stock rods?
Old Mar 31, 2004 | 02:27 AM
pornstarSR's Avatar
Default Re: (lsturbo707)
it would be a good idea if you plan to run higher horsepower on stock rods...
shotpeening works, but doesnt fix everything...
its just a kind of, better than stock type of thing, but not better than forged
Old Mar 31, 2004 | 07:31 AM
mh's Avatar
mh
Default Re: (pornstarSR)
shot peening is usualy used to give a hard surface and leave the inner part of the material "soft". this is often used to increase both strengt and the life on parts like gears. and since it hardens the surface if helps to reduce the chance that the part will crack. most if not all cracks start at the surface.
so i don't thin it will get you anyway near the strength of any forged rod, if that was what you were hopeing.... but it will have some more strength than a stock one. (how much all depends on the shotpeening, what matterial they use, the angle it's been blasded at, and for how long, on and on,...)
Old Mar 31, 2004 | 09:06 AM
thanks for the info. very helpful.
idewson
Jan 4, 2006 10:38 AM
THEUSED
15
Jan 9, 2005 09:19 AM
Mr HYDE
59
Mar 18, 2004 09:35 AM
NOSED_CRX_VTEC
Sep 12, 2003 11:25 PM
boostedinteg03
Mar 20, 2003 12:57 PM
