code 13 and 7???
Old Jan 14, 2009 | 11:20 AM
h22acd5's Avatar
Default code 13 and 7???
i recently had a diagnostic and i found out i had a bed alternator and some ground problems but the mechanic said he would have to go deeper in the diagnostic but he said there pretty universal so i was wondering if anyone knew what they codes were so i can fix them.
Old Jan 14, 2009 | 11:58 AM
MD426's Avatar
Default Re: code 13 and 7???
Code 0 Electronic control unit (ecu)
Code 1 02 (oxygen) sensor
Code 3 and 5 map sensor
Code 4 Crank angle sensor
Code 6 Coolant temperature sensor
Code 7 Throttle angle sensor
Code 8 Crank angle sensor (TDC)
Code 9 Crank angle sensor (CLY)
Code 10 Intake air temperature sensor
Code 12 EGR system fault
Code 13 Atmospheric pressure sensor
Code 14 Electronic air control valve
Code 15 Ignition output signal
Code 16 Fuel injector fault
Code 17 Vehicle speed sensor
Code 21 Spool solenoid valve
Code 22 Valve timing oil pressure switch fault
Code 23 Knock sensor
Code 41 Oxygen sensor heater fault
Code 43 Fuel supply system
Old Jan 21, 2009 | 07:32 AM
accord20o1's Avatar
do u know where this is on the f23? i swapped out the whole vtec solenoid and still have the code 22... i couldnt find out where the oil pressure switch is
jdmd15crx
Aug 18, 2016 06:45 PM
kizner
Jan 29, 2006 09:39 AM
4gnhatch
Jun 2, 2003 12:35 PM
